***Need Help With One Hose Under My Plenum***
  • ***Need Help With One Hose Under My Plenum***
    Following you see three pictures. I would like to know how to disconect the hose (see red arrow on third picture) on that end.
    Thanks Frank
    i cant see very well, but i think its the hose for the PCV mounted in the rear valve cover, it should just pull out.
      yea, if you just pull up it should pop off if I remember correctly
        ok thanks all :P
        But I have a another problem, the old gasket of my plenum broke on this hole in red. How could I remove the tip on my plenum.
        Thanks Frank
          I've had to use a pick before to pry it out. It sometimes required to break it up and dig it out. Definately a pain sometimes.
            Or drill it out. Something to just pick away at it. Its just plastic. Or even heating up a metal pick and putting it into the plastic then letting it harden to pull it out.
              ok thanks all
              Frank
