coolant in Cylinder 1
  • coolant in Cylinder 1
    I got a code that said cylinder 1 misfire. I took out the spark plug and it was drenched in antifreeze. So i did a compression check to all cylinder and compression was at 180 lbs for every cylinder, so signs of coolant in any other cylider. I changes my LIM gaskets thinking that was the problem, but after reassembly the car seemed to be running smooth. I pulled the plug out again from cylinder 1 and it was saoked again, I still have coolant getting in there. My only conclusion is that its the head gasket, but I don't see how if the compression is great in every cylinder? Any opinions? Is it possible the LIM is wapred? What else could it be
    RE: coolant in Cylinder 1
    Head gasket. Just Dooo eiittt
    I am back
    Mechanical/Service Technican
