i've heard the best way to prime the oiling system is to use an old 2.8 distributor. how is this done? i did a search but came up empty handed.
do i just grind the cam gears off and just bolt it in place of the distributor drive dummy shaft (making sure it engages the square oil pump drive of course) then spin the distributor with a drill until oil comes out of the top of the pushrods?
any advice suggestions appreciated, thanks
