timing an '84 2.8
  • timing an '84 2.8
    I want to time my '84 2.8 auto/carb'd with computer. Which wire (if any) do I have to disconnect to do this? I looked in the pax footwell area like a TBI setup, but no wire. Can I just pull the distr. connection? This thing runs just fine with both comp plugs pulled, so I guess that would do it too?
    The wire for your car may be in the engine compartment by the heater box.
    The best thing to do if find a wiring diagram. It will show you the location of the connection.
      If it's inside the cab, it will look like this:
      "The ESC Electronic Spark Timing "tan wire with a black stripe" that everyone can't find when attempting to set their timing (s-series). Wire is under the carpet on the passenger side below the heater box. It is disconnected to set the timing, then reconnected."
      Mike Campbell
      1988 3.4 V6 S10
      1991 4.3 V6 SYCLONE 12.4 @ 107 0-60
      http://www.sytyarchives.com/database...ser.php?id=147
      http://www.centergc.org/images/misc/...one2932?page=1
        Thats a good picture, is it on a carb'd vehicle? I have found it on a TBI 2.8 before, but this carb'd one seems to have it either hidden, or maybe somewhere else.
