hey guys! i have a 2003 buick century with a lg8. Its nearly stock with the only things done are
3400 tb
cone filter
added fuel past 3k
fans on @212F instead of the 243F the stock ecu had
so the problem im having and have always had is that this bad boy has so much ping its crazy. i can hear it when getting on the freeway (ive boosted a bunch of cars this is the first time ive ever heard ping first hand) and when monitoring/ datalogging it reads the knock retard up to 12 degrees! knock even higher! and it doesnt matter the load because in light load it pulls 6 kr. ive sinced switched to 91 octane and have noticed that i dont get above 8 kr.
plugs are brand new so i assumed the cylinders were a little hot and decided to command 13.5 afr when above 3k rpm and 40% throttle. This drastically changed everything from it feeling like a freight train to bringing kr back down to 5 or 6 under heavy load and 1 to 2 kr under light. Im at a loss of what could bring all this ping. coolant runs around 194F tranny around 145F so its not super hot. any help? lol
3400 tb
cone filter
added fuel past 3k
