Double stumped
  • Double stumped
    Pulled the fuel rail tonight, and turned the key on to look for leaky injectors...nada. Held fuel pressure this time, even. I did notice three injectors had "wet" around them BEFORE I pulled anything apart and spilled a little fuel in there.
    Question now becomes, which is more likely to be an "intermittent" failure? A fuel pressure regulator, or an injector? Also, the two "nipples" that stick out from the pressure regulator wiggled. Is this normal? I'm just about fed up with this thing. Thanks for any help you can offer.
