New to the board, thought you guys could help me out.
93 Lumina 3.1 210,000 miles. Driving the car today, ran fine. Left a stop sign and car had very little power, made it about 150 ft then oil light came on, then check engine light, then it just died. All in all about 300 ft from the stop sign. I can hit the starter, but it sounds odd. All the accessories turn including the crank pulley when i hit the starter, but the engine doesn't move. Pulled the oil cap, no valve movement. Put a wrench on the crank pulley and it seemed to turn pretty easy. Any idea? I figured it either spun a bearing and trashed the crank or the timing chain broke. If the timing chain broke, is this an interference engine?
Thanks
AW
Thanks
AW
