94 Olds. Cierra 3.1L .... Need to find CST location
  • 94 Olds. Cierra 3.1L .... Need to find CST location
    Hi all....
    I was wondering if someone could point out the location of the CST that is used by the gauge in my dash?? I know there are 2 CSTs. One that speaks to the ECM and controls the fan and the other signals the temp guage in the dash. This one should have a single lead if I'm thinking right.
    I had the dash gauge die on me and then started to work off and on. I figured I'd replace that sensor to rule it out before I went and checked/repaired the wiring. Any help would be greatly appreciated, Thanks!!
    Brian
    Sensor for the guage is in the corner of the rear head. The sensor for the ECM is in the lower manifold by the thermostat
      thank you sir, I appreciate it!!
