I recently had a used 3.4 dropped into my 95 GTP. Before they put it in I suggested they replace the timing belt since the engine had just under 70K on it. Listening to the exhaust at an idle makes me think the timing is not quite right. Maybe off a notch? What is the easiest way to check ? I am planning on doing a top engine gasket replacement soon, and thought that would be the time to check it out. Thanks in advance V6 masters!
3.4 DOHC Timing Problem
