Haynes says replace valve cover gaskets - should I ??
  • Haynes says replace valve cover gaskets - should I ??
    OK,
    I took off the valve covers because I had to remove my intake manifold. They look like they are in really good shape, should I replace them or just put a little RTV on both sides before reinstalling? They did not leak before and they seem really flexable still.
    Thanks
    Boring Lumina is a White 4-Door with 191,000 miles on a 1995 3100 V6. No mods and only minor repairs so far (Hoping the repairs stay to a minimum) Why yes, I am an
    Yes, save yourself a headache and replace them now, they're cheap www.rockauto.com
      I reuse them all the time. You can replace them if they do leak without too much trouble. If you RTV both sides, you wont be able to use them again if you pull them off 1 more time. It is best to replace them but honestly, I have used them over 6 times pulling them off without any issues.
        Cool, I gotta save time and money wherever I can. No RTV for me.
          I always replace mine when I take them off. The couple of times Ive tried to reuse the old gasket, its always stretched out too much to fit back in the grooves. Plus, they are only like $11 for the set. No RTV
          Robby Whitesell
          2006 Pontiac G6 GT
          1985 Toyota Pickup DLX
            You should put them in the freezer! Ask Lorenzo. ROFSMP!
            Brian
            3400 SFI V6, 4T60e
              ROFSMP? rolling on floor smelling my pee?
                Rolling on the floor saving my place? eh???
                Brian
                3400 SFI V6, 4T60e
                  ROFLSMP = Rolling on floor laughing shittin my pants......one of my buddies made it up on the way to watch Ohio State play Purdue in November
                  Robby Whitesell
                  2006 Pontiac G6 GT
                    i recommend always replacing gaskets once you take them apart
                    and rtv on a valve cover gasket is not a good idea
                    I Like V660s
                    Does Chevy make beer
                    ~Jayme~
