Flat Spot during initial acceration?
  • Flat Spot during initial acceration?
    I have a 95 grand prix 3100.
    when i'm at a full stop and start to press on the gas the car hesistes. that is the only time it does it. the rest of the powerband is just fine. even sometimes when i'm coasting and the rpms drop to 1000 and i press on the gas it hesistes.
    its a slight hesistation and then quickly starts to go just fine.
    why is this happening?
    recent mods: rsm throttlebody... i don't believe i was having the problem when i got it installed. it seemed like a few months later it started to happen.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    timing chain loose??
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
      Bad tps maybe.
        My 92 did the same thing and it was the TPS
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
          tps huh. expensive? can it be cleaned out. it was black as hell when i put it in my rsm TB.
            it ain't the tim ing chain. U CAN HEAR THAT LOL. it would make clank while starting up and go away in a few seconds depending on how bad it is. it hink.
              I tried cleaning the TPS once... Just made things even worse. I think you can get one for maybe $20.
                Timing chain will stretch sometimes...and if its a cloyes double roller, it will stretch in record time. That won't cause hesitation though...unless its pretty damn bad:P
                Not gonna clean it, just replace it.
                  Yea htere is nothing to clean. Test it for flat spots using a multimeter, an analogue one works best for this. If you see any just fire it in the garbage and go get a new one.
                    Yeah, its just a potentiometer (I guess), so there's nothing to clean. Plus, if you take it off, you'll see there's nothing to it
                    Robby Whitesell
                    2006 Pontiac G6 GT
                      cool. thanks guys. i'm selling a SNAP-ON multimeter in the FS section. i will test it with that before i sell it.
                        Clean out your intake manifold. Heavy carbon build up can cause lots of problems, including hesitation.
                        1989 Chevy Corsica LTZ
                        2.8L 60° v6
                        5 speed
                          So can a leaking EGR. The TPS is usually the culprit though, and the multimeter will tell you for sure.
                            won't heavy carbon build up kill my acceleration?
                              i had the same problem. but since i've installed my EGR adapter plate and digital EGR on my 2002 3100, the problem seems to have gone away.
                              1994 Oldsmobile Achieva (2002 3100 SFI)
                              Homemade ram-effect CAI
                              K&N cylinder filter
                              Poorboy Lowering Kit
                              Front STB
