if your cap isnt sealed your coolant will boil at 45 degrees cooler than if it is and if you have a 50/50 mixture thats not very hot
the purpose of the cap is to increase the preasue which increases the boinling point 3 degrees for every psi
most caps are 15 psi it a very important part of the cooling system
