help please!
  • help please!
    i have a 87 z24 obviously and i snaped my intermediate shaft what can i do? can i convert it to use 1990 cv shafts and not use the shaft?
    Ford ain\'t so bad.
    67 mustang 427 one bad ass car
    If I were you, I'd just pull one from a junkyard.
    How on earth did you snap that thing anyway? It's a frigging chunk of steel!
      help please!
      I installed the motor but the clutch yolk was holding the throwout bearing wrong. So when i pulled the motor back out it cought and snaped.Funny how i did not even know i had one my 1990 5 speed did not have one.
      the only z24 around in a junk yard is my old one a 88 auto it is not interchangable is it?
      Ford ain\'t so bad.
        also it is aluminum
        Ford ain\'t so bad.
          The intermiadte shaft (axle) is steel. Are you refering to the outer casing that is on some 5-speed trannies that enshrouds the intermediate shaft?
            YES I AM
            Ford ain\'t so bad.
              Yes i am sorry for confusing the shaft for the housing. it is also a 5 speed
              Ford ain\'t so bad.
