Hi all
First off, I have been reading very good and useful information on this site, but for some reason, all that I have read hasnt helped me out....
Heres the situation:
Bought car 3 weeks ago.It had bad head gasket,so I changed both. Started car up, and it ran, but not 100 %. The car has been sitting this way for around 2 1/2 years.
I put fresh gas and injector cleaner in, and ran it for awhile. Car had very little power. I adjusted TPS( checks out good ), took out IAC and cleaned/reset it..
New cap/rotor.I tested pickup and module, with VOM, and checks good, as does the coil. New AC plugs/Autolite pro wires.
Injectors ohm out at 16 each.
Cleaned intake/butteryfly.
Fuel pressure is 48# with key on. 42 with key off. When engine running, pressure is 42, but drops abit ( about 38 ) when speed is picked up to around 1500 rpm.Then it rises back to 42. ALso installed new fuel filter.
The car when cold runs alot better. As it warms up,its hard to maintain any speed, and I have to have the pedal about 2/3 down just to maintain 35 mph. When warm, it likes to surge and buck when trying to accelarate, and bark back through the intake ( timing is at 10 deg and plug wiring is correct).
On a cold startup, I have to keep feathering the throttle to keep her running. When warmed up, the idle is up and down-up and down ( 650 -1100 rpm ). I have checked many times for vac leaks also....havent found any
Installed a new collant temp sensor and O2 sensor.
The only SES code I get is a 44, and thats when the engine drops to around 400 rpm ( lean condition ).
What am I overlooking ?????
Thanks
Thanks
