Car ran fairly well when I got it. Replaced spark plugs and wires today. Now runs like shit. I used Rapid Fire #6s (they were pre gapped at .045 - I checked them all). For wires I bought the $20 ones at autozone.
Installed them. Car ran bad, I thought I goofed on wire placement on the coils but all checked out OK. So I figure maybe bad wires, pull one off and the terminal tears out of the boot and stays on the plug. So I gently remove the rest, twisting the rubber boot as I pull, every damn terminal on all 6 boots rips off. So, I think its running bad because these wires are obviously junk. I return the wires and get the Bosch set. I install them. Fire the car up, idles normal. Back out, it seems ok. At first it feels like most of its power back. BUT, under load, especially noticeable at high rpm, the engine surges and loses power. What the hell is going on?!
So to recap:
-6 fresh rapid fire #6s pre-gapped at .045
-New set of Bosch wires, triple checked to make sure cylinder/coil matchup is correct
-engine lacks some power
-engine surges, more noticeable under load and at higher rpm
-car is driveable, but annoying
-also changed the fuel filter with a purolator filter (are they unidirectional?? I installed it the way the old one looked but the bracket on the new one is clipped on so someone could have turned the filter around)
-I'm superpissed cause it ran a lot better with old crusty 100k plugs and original 13 year old wires
help!!
-john
So to recap:
help!!
-john
