Just thought I would post this here since I could find no accurate answer anywhere on the net. The backround:
My Son's 1998 Buick Century with a fresh 3100 in it periodically set code P0441 and NO OTHER CODES. Six months ago it came on permanently. New gas cap, no dice. New purge valve, no dice. Checked Vent Valve, no dice. Several sources on the net indicate this CANNOT be caused by a vacuum leak (WRONG).
I got desperate and built a "smoker" out of a paint can and some dollar store incense. Smoked from the front and since the cannister vent is normally open, it leaked from there back by the gas tank (normal). So I smoked the tank from the filler neck and smoke started pouring out under the car.
There is a metal vent line that follows the filler tube and filler vent under the car near the tank. There is a 6 inch piece of 3/4 inch flexible tube between this line and a plastic t-fitting in another line. This 6 inch piece had a hole in the top that you could fit your finger tip in. Looked like maybe a rodent chew or just old age caused it to disentergrate. Replaced this piece of tube with some scrap line from the garage and the code cleared in just a few minutes.
