Hey guys,
I have an 85 Firebird 2.8 V6 MPFI motor here with a fully documented 72,000 miles on which demonstrates oil changes every 6000 miles and a coolant change every 2 years. It's attached to the T5 manual box which I like and won't be changing.
The car itself is toast so I'm planting the whole drivetrain into a donor '84 shell which I've fully restored, and I mean almost everything is new! I've already replaced ignition coil, leads, plugs, rotor arm and dizzy cap and I'm fitting Pacesetter 70-1206 headers with a custom K&N cold(wish)air intake, new water pump, and want to pull the EGR and Air system, but leave the EVAP in place as I can't think of safe way of venting it while maintaining the tanks 2psi required.
I plan to whip the manifold off and replace all the gaskets but don't want to go as far down as the head gasket as after I had it running I see no need to replace them, unless you guys can say otherwise!
So my question is simply, do I have to tear this motor down to replace all the gaskets given it's amazing maintenance record and the fact that it runs great with no ECM errors?
Thanks in advance people
