Need Help Fast
  • Need Help Fast
    I have bought a 1988 S-10 engine ( 2.8 L ) to go into my 1989 RS. My question is are the heads and the cams the same? Should i use the heads and cam off off the orginal engine cause i have bought the engine complete and heard it run. I am just trying to figure out if everything is the same or different. I know the basics like changing sheet metal and water pumps, but other than that any suggestions. Thanks
    -Buck
    1989 Camaro RS 2.8L MPFI - 5 spd
    They should be the same.
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      Cam is not the same. Same profile but machined with a different centerline. An S-10 Cam has a lower torque peak.
