Have a 1992 Cutlass Supreme 3.1 MPFI. I bought it for $700, and it has a Jasper rebuilt engine with about 100,000 miles. It was a one owner driven by a woman, and when she died her husband let it sit for four years before selling it. He was not actively trying to sell it, but he said since I asked about it that it was time to let it go.
I have confirmed that the o-ring oil drive shaft assembly is leaking. It's starting to make a mess in the driveway, so it's time for me to take a stab at fixing it. I have an original 1992 Oldsmobile Cutlass service manual full volume(same as dealers used), and I could not find any repair and replace information in the manual.
Read a lot about replacing the o-ring, and there is conflicting information mostly regarding whether or not the upper intake/plenum has to be removed or not. My upper intake has the square look to it while the later models had the long runners some people call spider legs or what ever. I just need to know whether or not I need to remove the upper intake or not? Some say yes and others say no.
From just looking at it, it seems I could just disconnect the throttle body and the coolant hoses to throttle body, and there could be enough room to get it out of there without removing the upper intake. Money is tight right now, so if I can't get it out I was thinking about just raising it up enough to clean the area, and then apply some The Right Stuff gasket sealant on it, and calling it done. Not sure if it would seal the oil leak or not, but just thought this would be another option.
Let me know what you think, because the manual I have is not helping a bit. Thanks!
