L82 3.1 full motor rebuild
  • Question : L82 3.1 full motor rebuild
    As the subject states, I'm looking to do a full rebuild on my L82 3.1 once Spring hits. It's got a bit of a 'tick' (could be a rod or a lifter, not 100% sure which), so I want to do a motor swap and then rebuild the original. Can anyone give me a parts list I'll need so that I can start getting some prices now. I'm a slight amateur, so I don't know exactly what everything is called, especially the little things. All help is greatly appreciated.
    Its most likely a lifter. A rod would be louder and vary with engine load more so than just RPM. Is this a stock rebuild or are you looking to upgrade it any?
        Originally posted by Schurkey View Post
        Good book... however, while it barely touches on the Gen II engines, it has absolutely nothing about Gen III (roller cam, etc...) Unfortunately by the time the L82 3100 came around, the 60* was relegated to utilitarian status.
        - Ben
          To give you a parts break down, it would be best to pick up a service manual (not the typical Haynes-Chiltons book) and thumb through it.
          3.1 LH0 is not a 3100 L82, however this section is for the LQ1.
            Did I miss something? The OP states L82 3.1 and this is the Pushrod Maintenance section...
            Has the OP posted about this project elsewhere as well?
            - Ben
              You missed that it was moved from the DOHC section to here.
