By the way i finally found a use for my otherwise useless scrubs left over from nursing school!!!
Still trying to locate oil leak...
Originally posted by hal.lyman View Post
Is my #1 the number one in the diagram?
The bolt that you circled doesn't appear to be a major (if at all) oil leak, just based on the fact that nothing has really run down from that location.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
Originally posted by caffeine View PostLooks like it could be a weather-proof rubber piece from a wiring connector.
Can't remember for sure on the gasket. Swear that they are that short even new.
Thought you could also use the small block Chevy distributor gasket to help seal it where it touches the block. Or is that just for the 3100/3400? I was thinking the 60 degree drives are the same.Last edited by Purple pit; 10-23-2014, 01:51 PM.95 Beretta 3100 with 3400 intakes and TCE TB
Grand Prix trans with 3.33FDR
