Does anyone have some ideas?
I have a Fiero which is leaking oil into my coolant.
Originally the motor was built by a mechanic who put the heads on the wrong side. I decided to swap them over. When I did this I was very lazy...didn't use head bolt sealant, reused the gaskets, reused head bolts.
Recently I pulled the motor apart and did it properly; new gaskets, new head bolts and head bolt sealer(Indian head gasket brand). All surfaces carefully cleaned and torqued down to correct specs.
I am STILL getting oil in coolant. Does anyone have an idea as to what else could be causing this problem.
Cheers Tim
Cheers Tim
