Hey all. Just in case you're not familiar, here are the particulars.
-1996 Century
-3100 V6
-Just put in a fuel pump
-Now have codes P0441 and P1655
The internet tells me that 441 is EVAP purge flow fault, and 1655 is a GM-specific code with the following possible causes:
- Faulty EVAP Purge Solenoid
- EVAP Purge Solenoid harness is open or shorted
- EVAP Purge Solenoid circuit poor electrical connection
So they seem to be related. I thought they might have been caused by the fuel pump install, because when I installed the tank after putting in a new pump, the rubber elbow coming off the tank going into the charcoal canister line tore. I replaced it with some fuel hose and a clamp, then deleted the codes, but they came back within one key cycle. The internet also tells me that the purge solenoid is part of this thing I originally could not identify when taking it off to do the head gaskets (click for bigger):
Further, Rock Auto tells me that those parts are shared with the early gen 3 3100 only, meaning if I get a junkyard part, it can be no newer than 1999.
Any other advice? Am I barking up the wrong tree by thinking I need to replace the things in that picture?
-1996 Century
-3100 V6
