1988 cutlass supreme 2.8 MPFI, having problem of the fuel pump draining my battery dead. Tried pulling out the fuel pump relay but pump still runs, tried pulling off the oil pressure switch and pump still runs, pull out the 20 amp fuse and the pump stops.
what other switch is causing the pump to get +12V?? Here are some pictures of me probing the terminals with a test light with the car off.
oil pressure switch is a 1 terminal so I don't understand how it can run the pressure gauge in the dash and supply +12V from that 1 terminal. Anyways I ordered the switch and will be replacing it.
