flywheel balancing
  • flywheel balancing
    hi, i need to put a new flywheel on my engine, just wanted to know what the procedure in mounting a weighted flywheel was. its a 2.8 from an 87 firebird, going into an 86 s10. i dont want to bolt it up and have the weight be off balance, and cause a bearing to spin or something. thanks
    nobody knows?
      arent all pushrod 60v6s internally balaenced?
      1995 Monte Carlo LS
      3400 SFI 60v6
        only 88+
          Is your flywheel weighted? If it is, it should only mount one way. There should be a telltale hole on the FW, that matches a mark on the butt of the crank.
            it will only mount one way, all 660 motors use a non-symetrical bolt pattern on the back of the crank.
