2002 Montans 3.4 engine swap
  • #16
    No codes, Fuel pressure at rail, key on was 53 lbs. How do you tell if the injectors are spraying?
    • #17
      Noid light or pull the rail and aim the assembly away into a container cranking the engine a couple seconds or slightly longe. Thats after checking to make sure all fuses and such are goodr.
      • #18
        I wonder if the cam seized and broke and there is a cylinder with an exhaust valve and one with an intake valve open.
        If you crank it a bit does the oil pressure light shut off?
