No codes, Fuel pressure at rail, key on was 53 lbs. How do you tell if the injectors are spraying?
2002 Montans 3.4 engine swap
I wonder if the cam seized and broke and there is a cylinder with an exhaust valve and one with an intake valve open.
If you crank it a bit does the oil pressure light shut off?
Sent from my HTC One X using Tapatalk-60v6's 2nd Jon M.
