Okay, not really sure where to put this...
I need help with my lower radiator hose. It's stainless steel due to the fact that I needed a custom hose because my stock hose was getting crushed by my "wonder bar" frame brace (connects front frame rails of car through sway bar links).
The problem I'm having is that I have no heat (well, very little). The reason I have no heat is because I have the radiator fan set to turn on at 195* coolant temp. And the reason for that is because every time the coolant temp reaches about 200-205*, the stainless steel hose blows out of the rubber coupler. Yes, the coupler is tight. I've even tightened it with a ratchet and socket to make sure. It stays on the radiator neck and the hose blows out of it. The radiator cap is new-ish (bought it used, it's a Mr. Gasket Thermocap but it looks pretty new).
I have no idea why this keeps happening (it's happened twice now and I've lost several gallons of coolant and I would rather not lose my 70/30 mix instead of 50/50). I can't afford, with these cold temps, to have only half of the windshield getting defrosted and none of the other windows being able to be seen through. It's bad enough I'm having a problem with the vacuum doors in the system (possible bad switch--doors are opening that aren't supposed to, and I have one known bad motor I can't find a replacement for), but this no heat is killing me.
Anyone have any suggestions? What if I tried getting some bulk rubber hose about 6" long and used more than one clamp on the radiator connection on the stainless hose?
