o2 sensor
  • o2 sensor
    i have a 93 Z-34 and i can't find the o2 sensor to replace it. where is it?
    in the top of the rear exhaust manifold.
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
      o2 sensor
      how do i get to it? do i have to tilt the motor forward or is there a trick to it?
        tilting the motor should work
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
          hell, i remember that MY 3.4 DOHC wouldn't roll forward like the 3.1 MPFIs would. you could also try getting to it from underneath the car.
          K&N cylinder filter
          Front STB
            from underneath works the best, but if you have a long enough extention( peferbly locking and the right 02 socket you can get if from the top, but it's easiest from the bottom.
            2002 Pontiac GrandAm GT1
            3400 v6
            TOG headers
            RSM 62MM T-body
            FFP underdrive pulley
            GRANATELLI MAF
            Ported upper intake
            MSD DIS 4 ignition box
            MSD Wires and coils (pending)
            Venom high flow fuel pump (pending)
