Little history...original z26 quad4 powered car, engine kept messing up so i swapped in a 3500 and kept it 5 spd and did obd2 swap at the same time.
So my car surges then stalls, im thinking it has to do with vac lines. If i leave one vac port on the throttle body unplugged itll idle and not stall.
Need help routing vacuum lines to the fpr, map and the purge solenoids at the bottom of the coil pack assembly. Also since i have a 3500 upper intake manifold and lx5 throttle body....there is some vac ports on the throttle body that if i leave unplugged the car will idle 900-1000rpms with small surges but will not stall. I took it out for a spin with the small port on the side of the throttle body unplugged and usually stays above 2krpm while driving, will only idle at 1k at a complete stop. Did not stall.Any help/tips appreciated!
Edit: running stock 96 ecm with stock 3100 tune. Only difference im running 3.4DOHC injectors.
