CASE relearn
  • CASE relearn
    anyone try this? does it work?
    Originally posted by fullsizechevy
    NOTE: If the Crankshaft Variation Relearn is not accessible through your scan tool (some truck applications 1998 & later), perform the relearn in the following manner:
    1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
    2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
    3. Cruise at 55 mph for another 5-6 minutes.
    4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
    5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
    6. Accelerate to 55 mph and cruise for 2 minutes.
    7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.) with the clutch depressed. Refer to diagram A on page 8.
    its easier just to get your car reflashed at the dealer or whatever
