I've got a question about the DIS on the 3100.
If I have both plug wires off of the same coil, should a spark not jump between the wire terminals when cranking? Mine doesn't. And yes, it's got power and ground.
Also, what VAC reading should I be getting at the module end of the 7x CKP wire while cranking? It doesn't seem to me that I'm getting very much. From what I've read, the 7x is supposed to be pretty close to the reluctor ring. My TCE kit has the metal tip of the 7x about a half inch away from the notches, and that's with the bracket pushed as close to the damper as possible (it was bad enough I had to put washers in behind the bracket to get it lined up with the notches and yes, I do have the damper on all the way).
:edit: According to the pic on the britishcarconversions.com site, it looks like my standard 3100 7x CKP is too short? Pic attached below is from the site. I don't have one of mine, but the tip of the CKP is well inside the tube on the bracket.
