i have a 1995 olds ceira wagon with he OBD1 that was half OBD2,the problem i am having is it acts like its not getting fuel or spark when its under demand of acceleration.
the following parts have been replaced this month and show no signs of helping
fuel pump and sending unit
spark plugs and wires,coil packs and the computer that sits under them
fuel filter
cleaned mass airflow sensor
if the throttle pos. sensor is unplugged it will run a little better but still stumbles,misses real bad.when TPS is plugged in it runs much worse and i never get a code from any of this. what could be causing this?
also note car will start and idle fine.
fuel filter
