Hi folks! Sorry I've been offline for quite some time. Been working overseas and it's been crazy!
Anyway I finally got around to fixing the leaking steering pump on my 84 Century.
As far as I know the PUMP is original to the 1987 year engine (which i bought as a core engine). For quite some time, it has leaked oil slowly, so that if the car sits for a month or so, all the oil is gone out of the steering pump.
So, today I fixed it. I was quoted a high sum of money for a "rebuilt" pump of dubious quality. Forget the chinese knock-off ones. The seal kit was about $15.
This is a picture-intense thread, because that's the best way to explain the steps. There is nothing hard about this, but you do need a couple special tools (pulley remove / install tool, and drill press). The puller is available for rental from Advance Autp Parts.
There are several variants of this pump. The main difference is the shape of the reservoir. The repair procedure is the same for them all, aside from the reservoir removal could vary a little.
The pump was very dirty, so I put some plugs in the ports and pressure washed it. If you take it apart and get dirt and grit in the pump, it will be irreparably damaged.
Next, install the pulley remover tool. It simply presses the pulley off the shaft, by the hub groove. It is important that the shaft is never pressed into nor pulled out of the pump. Always press by the pulley hub groove.
Now, remove the 2 clips and take off the reservoir. The inner 'tabs' pry up, and then the clip can be slid off with a screwdriver.
Next, the pump cartride has to be pressed inwards from the rear. This will allow the retaining ring to be removed. Set the pump in a drill press, with the shaft down, through the hole in the drill press table. Use the drill chuck (not spinning, just pressing down) to press the pump cartridge into the housing. It goes in about 1/8".
Pop out the retaining ring.
Now, tap lightly as shown. The pump cartridge will slide out. Be careful so that the cartridge doesn't fall apart. The vanes need to stay in the rotor in the same slots, in the same direction.
Cartridge out. Make sure the vanes stay in the same slots, and they are in the same orientation in the slots. It's best NOT to remove the vanes. If they fall out and all get mixed up, you can study the wear marks and make sure they are all in the same orientation.
Now, for the shaft. Take the retaining ring off, and the shaft can tap or pull out. I used a steering wheel puller, but the shaft pulled out very easily. The shaft is very hard, so if you tap, use a soft hammer on the small end. It could chip off if hit with a hard hammer.
The pump completely apart.
This is the repair kit.
New shaft seal installed. Apply the Loctite to the outside of the seal. It is a metal-clad seal and must have sealant on the outer diameter to seal against the matel-on-metal joint to the housing bore.
Now for a tricky part. There is a pin in the pump housing, and 2 slots in the cartridge where the pin can go. This must be lined up correctly. When the o-rings are in the pump it is hard to tell if the pin is going in correctly. Before installing any o-rings, make a test-fit to get the pin lined up. Then, make a paint mark. This way, when you are pressing the pump together with the o-rings and spring in it, you can use the paint marks for a guide to ensure the pin goes in the slot.
Now, take it back apart and install the o-rings and the spring.
Again using the drill press, this time with the pump in SHAFT UP position, press the cartridge into the housing. The o-rings should easily compress. If there is any binding, stop and check the pin alignment. Be careful so that the cartridge doesn't come apart.
Your pump should look like this:
Now, remove the rear seal from the bearing. Clean it, and re-pack it with high temp longterm grease. The bearing is a special one with a very small clearance.
Now the regulating valve. It regulates the flow to a constant flow, regardless of engine RPM, and limits the pressure to a set level. It is application specific between rack-and-pinion and recirculating-ball steering boxes.
The fitttin needs to be very tight, otherwise the fitting will come out before the line nut can be loosened.
Now put the new o-ring on the reservoir and install it.
Now, install the pulley. Use the installer tool. Do not under any circumstances hammer or press the pulley on!!!
This should be the finished pump!
On my car, it looked like the previous owner had replaced the steering gear before I got the car, so it is not leaking. Normally if the entire system was old enough for the seals to be hardened, both the pump and the steering gear would need re-sealing.
Sincerely,
David
Sincerely,
David
