ok here it is ive done almost everything to this car i replaced the
pcv valve
swapped out egr (took it apart and cleaned all the carbon out)
cleaned out the intake(minor p&p job done by myself on the upper)
tps sensor
map sensor
new plugs and wires even the coils too msd ones they were the same price
changed fuel filter
swapped out the vacum cannister that plugs into the front of tranny
injectors professionally cleaned out
all this stuff helped out alot i even got a nice power gain accross the whole powerband but when it warms up like you have been driving for a little while and you start to drive it hard like a 0-60 run or something like that it develops a sputter that can be sometimes cured by shutting the car off for a few and restarting it but then it comes back again with the more agressive use of the gas pedal. someone told me that if i replaced the catalytic converter that it would help it out or would hollowing it out just to see if it helps the problem of course and buying a new one if needed please help ive done everything to this car.
pcv valve
tps sensor
map sensor
changed fuel filter
