Hi All...
Wanted to see if you all agree with this diagnosis: My faulty air pump is throwing off my mix and causing bad gas mileage.
To explain....
I was testing to see that my Secondary Air System was working properly. I discovered that the "Integral Stop Valve" solenoid that is built into the air pump doesn't react to a 12v signal... (no click or anything) and you can blow through the hose all the time. (the motor does work however)
When my engine is running in closed loop and the air pump is not on, there still can be felt a suction going into the input hose of the air pump. (I guess a venturi effect from the exhaust?). I think it supposed to be completely blocked off when the pump is off.
I monitored the voltage on my O2 sensor, and when I blocked the pump input hose with my thumb, the voltage on the 02 sensor immediately shoots up to to about 800mv for about 5 seconds, then levels out.
To my thinking, this indicates an always lean condition... one that is causing too much fuel to be put into the mix.... and that I need to replace the pump or fix the internal stop valve...
Does anybody concur with this?
To explain....
