i found a guy that has a 1993 camaro rs, 5 speed 3.4 v6 that i checked out earlier today. clutch felt good and grabbed, the engine had power and felt okay. suspension checked out fine. brand new tires. no exhaust leaks. body has zero rust and only has clear coat peel and a small dent that can be popped out.
my concerns are....
i noticed thick oil in the coolant. and i mean thick. i know gm engines are notorious for lower intake gasket leaks, but wow can it cause the coolant to get that bad if neglected? i checked the oil, and the oil definitely needs changed, but had no evidence of coolant in it.
second i noticed the car has a vacuum leak somewhere, and i noticed an engine light show up as well. i didnt pull the code, but when i drove it, the code would only come on when it was sitting at idle. but when i went to take off and drive, it goes away.
also when the car heated up, i would step on the gas to rev it somewhat at an idle, and it was like the engine did nothing and wanted to stall, unless i eased the gas in. then it would rev. and the car would stumble and feel like it would die
i went to shut the car off and pulled the dipstick, and there was blow by coming from the dipstick.
from my understanding, blow by in the crank case is caused either by bad piston rings, or a fault in the pcv system right? so im hoping the blow by is being caused by the vacuum leak POSSIBLY in the pcv system. because at an idle vacuum is high and flow is low, and when going vacuum is low and flow is high. so with the vacuum leaking at an idle, the gases are not venting. and when driving the gases are venting like normal.
could this be the case? i dont want to drop 1000 dollars into a car that has bad piston rings.
my concerns are....
