my issue was plug wires, i had a very similar issue are your discribing. wait for it to be dark, get a spritzer bottle and soak everythign down while its running, and you will find you issue, or hear it.
Car running awful...
Originally posted by 3400-95-Modified View Postfind a stable map reading when scanning it?
Originally posted by bob442 View Postmy issue was plug wires, i had a very similar issue are your discribing. wait for it to be dark, get a spritzer bottle and soak everythign down while its running, and you will find you issue, or hear it.
Could be timing chain jumped one gear notch back. Would retard the timing and cause the exhaust to be quieter since the exhaust valve would open later in the cycle. Though intermitent I would guess electronic issue.
Bad spark cables, bad battery cables/connections, failing TPS, etc1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by TGP37 View PostCould be timing chain jumped one gear notch back. Would retard the timing and cause the exhaust to be quieter since the exhaust valve would open later in the cycle. Though intermitent I would guess electronic issue.
It happened twice.
I patched up all of the vac and exhaust leaks, got her re-tuned and she's back to beastly.
Although the timing is still off (when you have it reting to run stoich or close all the time I get tonnes of knock, had to add timing to get rid of knock).
Could be a rattle/exhaust touching something?
I think my crank sensor needs changed as well (I get an oscillation almost like the signal during accel + the 1-2 shift aint right... buddy had the same symptom, changed his and it went away so I'll give it a go as well!).
Thanks,
Mike
Adding timing to get rid of knock doesn't sound right. Usually it's retard the timing or add fuel, I thought.-60v6's 2nd Jon M.
What timing tables did you start with? And you do know there are multiple tables in the bin that will alter the "good fuel spark table" right?
I could have mis-interpreted it... I was speaking out of verbatum...
All I know is that he did get rid of the knock.
Not sure what tables he did or didn't use..
Also got some sort of rattle going now too... sounds like the exhaust (I'm getting a shit tonne of movement in the CAT & flex pipe for some reason...).
Should I be concerned?
Originally posted by Fireball View PostI could have mis-interpreted it... I was speaking out of verbatum...
Should I be concerned?1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by TGP37 View PostDepends, you might be dumping fumes into your engine bay/cab. Exhaust easily rises into the cab and months of exposure is really terrible for your health.
Before there was a distinct exhaust scent in the cab... I remember it would make me feel like crap to drive it.
Now, there's a scent, but not out of the vents... don't really smell it while driving.
You do however smell it if you pop the hood and sit there...sometimes... it's almost intermittent.... like it may be coming from the EGR or something??
However I know whatever it is, it isn't pre O-2 as that's functinoing properly (not as if it's getting unmetered air like before).
Bloody headers...
