If your front o2 sensor is failing then the engine has no idea what the air fuel ratio is and can lean out the engine unknowingly and detonate and break a piston or break something else. The o2 sensor that is pre cat is a very important sensor for fuel monitoring... The SECOND o2 sensor, which you need to really start asking what the code number is so you can identify which is throwing the code, Can be ignored at least for right now since that sensor will not hinder performance or cause anything to break, but it could point you in the direction of having a failing cat which could begin to clog and cause other issues.
My suggestion... Go buy a code scanner from Wal-Mart... Stop relying on the mechanic who broke your car to tell you the codes.
