Well, the one I have on now should not be cracked.
The one they put on the first time was my stage 1 manifold. They ended up cracking that pretty bad in the upper, middle.
Had to go home and grab the stock one so they could place on the stock one for now.
So I suppose then, they could have cracked the stock one as well, since they cracked the first one.
So, coil packs are out since the misfires are random, and the fact I got an 02 sensor code leads you to believe it is another manifold crack?
Okay, I will take it back in and have them check it-hopefully, it will not be another manifold crack. I will be really upset if they cracked two manifolds of mine in a row.
