Hi new to forum, and here's my problem:
Mother-In-Law drives a 1997 Buick Skylark custom with the 3100 V6 with 170k miles. She brings it to me cause it's lurching and she thinks the transmission is failing.
I can tell it's running rough so I take it down and pull the codes and they cascade...
P0300 misfire
P0140 O2 sensor-bank1 sensr2
P0141 O2 sensor-heater circuit bank 1, sensr2
P0121 TPS
P0401 Egr
This car hasn't had a lot of maintenance; MIL puts gas in it.
I'm thinking these problems are all related to a prolonged misfire situation. Start with plugs/wires (the rear plugs look like the originals), I pull the throttle body and EGR, remove a ton of build up and make sure the pintel is free to move in the EGR itself. Replace the TPS. Pulled the IAC and cleaned it.
I put everything back together and see if it runs.
Now the idle is high on start up. Smooth, but fast
Will the O2 sensors settle down with fewer misfires or do I need to replace them? I'm loathe to just throw parts at this car, especially hard to reach parts. Also might be a bit low on coolant.
Am I overlooking any easy fixes?
Thanks for any advice
P0300 misfire
P0121 TPS
P0401 Egr
