Please Help again!!
  • Please Help again!!
    Ok so im back again and i need some help again my truck will not run it died on me last night and it will not start back up and there is spark and also fuel in the fuel rail and there is 45psi in the fuel rail also it will crank and start for like a split second and run but then i can spray starting fluid in the intake and it will start and run as long as i keep spraying it i have the vats system hooked up and i canned it and there is no codes that the comp will scan so i was wondering is there any way the injectors can be getting shut off and its a 3.4 v6 out of a 94 camaro
