The trans is commanded to shift determing few things. It must not be in P/N, both RPM and MPH limits are reached for shifting and the trans is functioning properly.
I remember noting the auto trans fluid. If the level is too high or too low the trans WILL not operate properly. Many functions rely on the ATF being proper. As in it can not be burnt and must have the right amount. Also, too many people will balance the ATF from the dipstick reading when cold and off.
The shift is done by fluid pressure acting on a piston under springs. Low fluid will prevent the piston from being pushed, too much fluid will make bubbles and bubbles compress preventing the piston from shifting proper. The auto trans is connected to the crank via fluid. There is no solid connection, the ATF is used to transfer power from the crank to the trans. Burnt fluid, bubbled fluid, low fluid will hinder that.
The only way to properly fill the auto trans is to do so while the trans is hot (warmed up from driving) and the engine ON. otherwise the fluid level will not be correct.
If the fluid level is not correct, you will have shifting problems, you will have a lack of power, the car will burn a lot more mpg in fuel.
Don't assume anything, and tell me, did you check the ATF level when the fluid is warm and the engine is running? Is the fluid red or brown and smells burnt? Seriously, 1-2 qts too low and you'll have all kinds of trans issues.
