ill explain this is simple and Easily as possible.........
Say you get in the car, turn it on, put it in Drive, you punch it to the floor, the car picks up speed as normal, BUT Feels as if the whole transaxle is shaking, and it feels as if it is coming from the whole front side of the transaxle/engine assembly is shaking forwards and backwards as the car is accelerating but it ONLY Does it when you punch it, Imagine if a Control Arm/Tie Rod end broke off and the Wheel closest to the front of the engine Can Sway forwards and backwards, thats as best as i can describe this
and i will admit... Yes we do hit the gas quite a bit to avoid the idiots on the road, i seem to have a (Crash-into-me) magnet...
But now the car is starting to consume more gas than normal..... i took it to AZ the guy printed me 4 codes here are as follows....
P0301 - Cylinder 1 misfire (has always been there idk whats causing it, no idea)
P0404 - EGR Code
P0446 - EVAP Purge/Vent solenoid circuit condition (WTF is this?? O.o)
P0452 - Fuel Tank Pressure Sensor
i did buy an aftermarket pump from a reputable guy on ebay, and I myself installed it, but theres a problem with it that i think I caused, the gas needle will go up to full at random and stay there then go all the way back down to where the level actually is.
All the help is appreciated...
My 86 Civic is in the process of being painted and as soon as its done i myself am never driving this buick again (not to diss GM, i want a GTP, but F this Century in the rear)
P0404 - EGR Code
