Okay, I was driving along, and I came to a stop sign, and my car just dies. No loud noises just dies. I have it isolated to the fuel pump... I think. It gets voltage up to the connectors in the back seat, but from there to the pump, the voltage drops. I'm thinking I need to replace the wires/ connectors. What do you guys think?
Fuel Pump Problem
take a rubber mallet and smack the bottom of the tank a few times, report back
You've probably done all these steps...but just in case:
95 Pontiac TransAm Fuel Pump Replacement as a generic analogue to your car (Sorry about the 4th Gen and V8 Part though):
Part One
Part Two
And so THIS extreme effort cries out for a "Trap Door Access" solution to be able to avoid having to do it this way.
IMPORTANT SAFETY ISSUE!
Assuming from your name that your vehicle is a 1992 Pontiac Firebird... the tank template locations and dimensions will be much different... so you will have to find a proper thread specific to doing this job unique to your car! DO NOT USE THE 4th Gen F-Body Trunk Panel Dimensions to make any metal cuts!
Part One
Part Two
I don't know enough about that F-Body generation to say where the fuse might be located. May I suggest a visit to eBay and using this link, you will find your Official GM 1992 Pontiac Firebird F-Body Carline Series Shop Manual at very reasonable prices? That is the only real reference to rely upon for searching around your chassis and finding how things are hidden and arranged, short of having an ALLDATA account:
there is no fuse between the water tight fitting and the tank side. The only fuel pump fuse is under the dash.
can you hear the pump run when you click the key on?
If you have the access panel cut, changing out the pump shouldn't be too bad.
