Need help please!
  • Need help please!
    Ok so i just did a 3.4 sfi out of a 94 camaro in my s10 its a m/t the problem i am having is that it runs for a few seconds then shuts off i changed the fuel pump i have 45 psi in the fuel rail then i have power to injectors and everything is hooked up as in motor wise im 16 and i know stuff but im just stumped on this one so please if you can help that would be great!
    While I'm hardly the most up to date on these, it sounds like what happens with a bad MAF sensor (assuming your S-10 uses one). You might try starting it, then disconnecting the sensor before it shuts off, if it keeps running, then it's either a bad sensor, or something to do with it (bad connection, etc).
    Mike
      yes, and do a double check of all your intake sensors.
        If you're using the Camaro PCM it could be VATS (Vehicle Anti-theft System) kicking in. It can be bypassed pretty easily, search "VATS bypass" for more info.
        If you're not using the Camaro's PCM just ignore this post
        "It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
          Yeah i figured it out after i scanned the truck and it came up with the anti theft system kicking in and i checked the injectors to see if they have a pulse and it would kick off cause the theft system so i wired in the box and everything runs right(; thanks for the help though guys really appreciate it!
            Excellent!
            Good luck with your truck A.F.W.
              Excellent!
              Yes! And thank you its coming along nice.
                post pics !!!
ID:	376965Click image for larger version
ID:	376966Click image for larger version
ID:	376967Click image for larger version
ID:	376968Click image for larger version
ID:	376969Click image for larger version
ID:	376970Click image for larger version
ID:	376971Click image for larger version
                    Not bad I'll bet its fun to drive
                      Yes it is but thank you though it has came a very long way
