The subject line about sums it up. I've got a '96 Buick Century that I've owned since new. Meticulously maintained with oil changes every 2-3k, hoses and coolant replaced every 5 years (dexcool). I keep an eye on it.
Last year, I noticed a slow accumulation of a black substance in the coolant reservoir. I'm not sure what it is, but I can only assume it's oil or transmission fluid.
In 2002 the LIM gasket was serviced (extended warranty - I usually don't buy those, but this time I'm glad I did
The oil is CLEAN, and I mean there's no sign at all of any coolant in the oil. It is using coolant, but I'm not sure it's related as my wife has commented on odor in the cabin. I might have a heater core issue, but I'm not sure.
The engine has about 148k on it, and otherwise runs fine aside from the cold engine piston slap that it's always had.
Where would I start to troubleshoot this? As it is, the cooling system needs to be opened because the thermostat is stuck open (been that way for a few years). I plan on replacing that, but I'm not sure this is the time, as a fully heated engine will probably stress whatever problem it's having.
What could this be? Head gasket? Leaky trans cooler?
Any thoughts?
Thanks!
Ken T.
Any thoughts?
Thanks!
Ken T.
