Just did the LIM gaskets on a 1997 Lumina with a 3100. Got it all back together, and it won't run. Backfiring/misfiring badly, sounds/feels like some of the plug wires are off. I've triple-checked the wiring though, and I can't see anything off about it. Advice?
3100 LIM Gasket Replacement Problem
Did you follow the numbers on the manifold for your plug wirings? Is so, then they are backwards.
Brad via Tapatalk-Brad-
Originally posted by bszopi View PostDid you follow the numbers on the manifold for your plug wirings? Is so, then they are backwards.
Brad via Tapatalk
