ok, so my car is down at the moment, it's a 3400 turboed Monte Carlo with 42lb injectors. I was driving in highway and it stalled while I was driving around 55-60 and I managed to coast it through an exit and up a hill somewhat enough for a couple friends to help push me to a parking lot.
most recent things I have done was put seafoam in oil,gas and intake. and installed a adjustable fuel pressure regulator. I was still running lean after the afpr so was experimenting couple things on cars since it kept flashing 20 afr in my o2 wideband. so I unplugged the maf sensor, and idle went to 14.3-14.9 or something like that so I though I take it for a test drive with and shortly after it stalled. but I noticed that when I drive it stayed at 14.7afr even at around 2-3k and when I let go of the pedal the afr jumps to about 13-11 afr, which makes me suspect fuel may be flooding engine?
It cranks and seems to start for a split second or so, and dies. I replugged the maf sensor. I tested fuel pressure and it was reading about 42-45lbs. I dunno if ignition is fine, but going to check the plugs tomorrow. I tried everything I could think of tonight. I disconnected battery reconnect, relieved fuel pressure through valve, check all vac, waited gave it an hour to 2 and restart etc. Also battery and alternator is good.
Tomorrow I plan on borrowing a obd2 reader to check it, and also check the plugs to see if it was flooded or so. Another theory is that the pcm died? is that possible and on the side is all 3400 pcm swappable? like can I go to a junkyard and get a grandam or malibu 3400 pcm and plug and play?
anyone else that broken down like this? I mean no puddle of anything, and when it stalled no loud breaking poping sounds, it was a silent deaf or so. Normally if sometime major is broken it would show a sign right? as in the pushrod, piston etc isn't blown?
