Yup, the 3400 in our 99 Venture just busted the cam & left my wife stuck about 1 mile from home. I'm puzzled since it never had coolant into the crankcase. I did a LIM some years ago because it looked like it was starting to lose coolant to the outside. Then a year ago I replaced the head gaskets when the front bank started leaking. She said the oil light was NOT lit, at least until it broke down.
So I'll have to dig into it to at least see how seized it is. I know every time I drove it the oil pressure didn't seem to be an issue, at least it came up fast enough to turn off the indicator.
Now I've heard you can't replace the cam in a mini-van without pulling the engine. Every time I've done the LIM I've looked across the lifter valley and it seems possible to come out the wheel / strut area if you lower the engine enough. Possible?
